After breaking down yesterday (total loss of power and unable to start thereafter), i have replaced the fuel pump relay, checked the power to it, the coil, spark and everything else is good.
When i turn on the ignition, the sender unit is not priming with a burst of fuel. I can normally hear it whirr as i get in the car but it doesnt seem to do anything now. I hotwired the pump independantly and that works perfectly....:confused:
Is the sender known to just fail all of a sudden? And if not, any suggestions?
Help would be massively appreciated, need to get it working ASAP!
cheers :p
You dont say that you have checked the fuses either, It may have power to the relay but a fuse still might have blown or may be corroded.
should have mentioned, fuses are all fine, and i am getting a single reading of 10-12 volts from one of the sender wires but nothing from any others. Im not sure which wire is which either....
bump...
I have checked the pump and sender alone and both work fine. The sender will not prime though when i turn on the ignition and will only run when i hold the relay gate closed. Even when holding the gate closed and turning her over, she wont start.
This is killing me! and i need the bugger to start for the weekend. Any help would be HUGELY appreciated!
