Hi all
With the help of you guys I,ve manged to wire up the lights ok but I've hit a snag with the indicators/relay connections.
I have a 3 pin relay with the numbers 49, 49a and 31 but Ive got four wires that need to be connected, (bearing in mind the type of switches and stalks i'm using below) I cant for the life of me work out where I'm going wrong.
Single column VW Indicator stalk with these coloured wires
White
Brown and white
Brown
Black and green
Black and white
and black and white with a green collar every now and then
7 Pin VW push/pull light switch with the following numbers on them
56, 57, 58, 58b, two 30,s and an "x"
5 pin Relay with the following numbers on them
"S", 30, 56,56a 56b
Total respect guys
Discussion Starter · #2 ·
Doh - I just looked at the diagram that you sent me to download and all the ifo was there. Thanks again
