Status
Not open for further replies.
1 - 20 of 41 Posts
petronix digital rev limiter £80 posted
set of day moulding upright headlight front wings in near new condition really thick grp amazing quality £50 collection only
will post pic if required
set of 90.5 mahle p&bs only done a couple of thousand miles match weighted as good as new and run in for you will include a set of new teflon buttons £100 collection only
1 5/8 merged header with stinger bit of suface rust but will clean up no problem
£80 collection only
8mm chromoly cylinder stud set with nuts and washers £30 inc postage
used web 121 cam with followers and will throw in a set of wide pushrod tubes they have a bit of surface rust but clean up ok
also the chromoly push rods if they of any use they are matched to this cam was running stock rockers with swivel feet and used two shims
£60 plus postage
check the spec on the speedshop sight this is a wild cam:D
Discussion Starter · #15 ·
Alright mate interested in the wings!! Please can I hace a piccie and im in Saltash!!
Scott
why dont i take them to work with me as i work in saltash and i could pop them around for you to have a look at that way i can finally see your bug:D
1 - 20 of 41 Posts
Status
