501 - 519 of 519 Posts
Discussion Starter #508
Raining here in Cumbria today so didn't get a chance to work on my caravelle outside.
I did manage to raise the bugs suspension 3 or 4 teeth on the Puma adjusters.
Increased the tyre to wing clearance from 28mm to 56mm which will hopefully stop any rubbing.
I also sanded the wing lip, rust cured it, etch primed and filled it.
You've made me look at my wheel arch to tire on the front and I've notice the passenger side wing is closer to the tire
Discussion Starter #513
Been lashing it down today so working outside has been a no no.
Managed to get the arch edge sanded down and some paint applied to keep the damp out instead.
The chinesium passengers side mirror i fitted a year ago has loads of rust spots showing through the chrome already even with a couple of coats of wax applied.
In comparrison i found the old drivers side one half buried in the ground behind my shed where its sat on the scrap pile for the past 5 or more years and the chrome is still 99% perfect. :rolleyes:
Discussion Starter #515
Have I missed something? I thought all the paint and bodywork had been finished?
It was but with 2 up when turning right up hill the passengers front tyre caught the arch lip and burned the paint off. :(
Its a repro arch on that side and the profile is not quite the same as the genuine one on the drivers side which gave loads of clearance.
EMPI replicas with a silly low offset, 185/65/15 tyres and a stock width beam don't help either.
Discussion Starter #517
Finally got around to soldering the two speaker wires back on. Radio now plays though all 4. :)
Still thinking of fitting a small subwoofer in a box behind the back seat as any bass in a song just makes the speakers crackle.
