661 - 680 of 713 Posts
Discussion Starter · #663 · (Edited)
Decided to raise the rear end one outer spline as got fed up with the sound of the towbar scraping along the road.
Motor vehicle Automotive tire Vehicle Automotive exterior Car
Torsion bar cover removed and axle unbolted.
Motor vehicle Automotive tire Blue Tread Tire
Spring plate knocked off the step.
Tire Wheel Motor vehicle Automotive tire Bicycle tire
Spring plate removed.
Tire Wheel Automotive tire Motor vehicle Hood
Reinstalled one spline up (or down?).
Wheel Automotive tire Motor vehicle Tread Tire
One spline round.
Tire Wheel Water Automotive tire Motor vehicle
Decided to raise the rear end one outer spline as got few up with the sound of the towbar scraping along the road.
attachFull115388
attachFull115387
attachFull115386
attachFull115385
attachFull115384
One spline round.
attachFull115393
Pics not showing for me?
Discussion Starter · #666 · (Edited)
They aren't for me anymore either. :unsure:
Give me a sec.
Gonna replace the fuel filter while i have easy access to it then torque everything back up and make a start on the drivers side.
Discussion Starter · #667 ·
Passengers side all back together and torqued up.
Needs a bit of bouncing or a run around to settle the suspension but it looks like it'll be about 40mm or so higher than before.
Tire Wheel Car Vehicle Automotive tire
Changed the fuel filter for a nice new clean one while access was available.
Automotive tire Motor vehicle Automotive lighting Vehicle brake Rim
Old one looks like it'd been filtering coffee. :oops:
Fluid Bottle Glass bottle Gas Wood
Made a start on the drivers side before the cold started getting to me.
Automotive tire Saw Wood Gas Auto part
Discussion Starter · #672 ·
Its now sitting at this height with a decent amount of clearance under the towbar. Its not been moved or driven yet though as i managed to strip the thread on one of the lower shock mounting bolts. I was tightening it and it started to tighten up against the lock washer then just spun. :mad:
Car Automotive parking light Vehicle Automotive lighting Hood
Automotive parking light Tire Wheel Car Land vehicle
Discussion Starter · #677 ·
The Sony stereo i have in the glovebox has been playing up for a while now. I now suspect its a dodgy connection somewhere as it appear dead when the source button is pressed but will just start working again while you're driving along. Possibly a loose connection somewhere though i've not been able to track it down yet.
I was greeted by a totally flat battery as its obviously still taking power but just producing no sound and no display so its been on for nearly a week silently draining the battery. :mad:
I'm quite tempted to just say sod it and replace it with one of these mega 瞿18 cheap ones off ebay. The sony is way overpowered for the speakers i have anyway.
White Light Gadget Hat Eyewear
Discussion Starter · #678 ·
Took the bug for a quick run around to settle the suspension. Much less scraping now. I think the tracking could do with checking though as its a little bit wayward.
Tire Car Wheel Automotive parking light Vehicle
Tire Car Vehicle Sky Plant
Managed to get the choke flap stuck in the fully closed position when i refitted the air cleaner last so she wouldn't run properly after she started. Took a few minutes for me to figure that one out. :rolleyes:
View from the drivers seat.
Car Vehicle Speedometer Motor vehicle Automotive design
Discussion Starter · #680 ·
Apparently setting the toe in to 3mm with the wheels off the ground equates to around 4cm once its back on its wheels. I did not know that when i replaced the track rod end at MOT time.
No wonder it was a bit wayward, it was constantly fighting itself to turn one way or the other.
Took it for a run around and its a lot nicer to drive again.
