81 - 93 of 93 Posts
Discussion Starter · #81 ·
Totted up the hours i've spent on it. 72 hours work so far. Still a little repair to do on the inner bottom of the drivers door and the sliding door needs some serious adjustment so the bugger actually fits the hole instead of sitting 1" out and about an inch too far back.
Discussion Starter · #85 ·
Got filler sanded on the front end and some primer on.
Tire Wheel Vehicle Hood Automotive tail & brake light
Automotive parking light Automotive tail & brake light Tire Grille Automotive lighting
Been trying to get the sliding door to fit and close properly and failed miserably.
Its had a late door fitted to an early van (everything changed in 1985) and they've bodged the catch and striker at the rear of the door to lock it but theres nothing at the front at all. Theres this adjustable plate with an indent in the B pillar that something on the door fits into to keep it in place but theres nothing on the door to match and nowhere to attach it to anyway.
Tire Automotive tire Motor vehicle Automotive lighting Wheel
Found this picture online showing the rubber buffer thats supposed to be attached to the sliding door to meet up with the recess in the B pillar. As its a later door theres no captive nut in the frame to attach it to so hopefully i can just put an M6 rivnut there to screw it into.
Wood Door Automotive lighting Vehicle door Automotive exterior
It seems like the door is flush with the body at the top and bottom but nearly 1/2" proud in the middle. Doesn't help the new seal is solid rubber at the corners.
Automotive parking light Tire Wheel Automotive tail & brake light Land vehicle
The bracket the bottom roller attaches to is bent aswell.
Its just getting stupid as its had so many bodges i'm just chasing my tail trying to fix stuff.
Gave the primer a little sanding and sprayed some gloss black aerosol paint on.
Automotive parking light Automotive tail & brake light Grille Automotive lighting Motor vehicle
Car Grille Vehicle Motor vehicle Automotive lighting
I'm still trying to get the replacement headlight i was given to fit the mounting frame as the old and replacement are slightly different with the mounting tabs not quite lining up.
I think it'll be easier to adjust the position of the tabs for the screws on the steel mounting frame rather than trying to attach new tabs onto the headlight.
Discussion Starter · #88 ·
Finally got the replacement Hella headlight fitted (after welding on 3 new brackets as the didn't match the screw holes) and refitted the grills.
The lower one was missing 4 of the 5 fixings and the top one was missing 2.
Car Vehicle Hood Automotive lighting Grille
Had a go at adjusting the sliding door and its just as bad as it was, with a huge gap at the front you can stick your fingers through. The corners of the new seal are solid rubber so don't compress when the door is closed.
Discussion Starter · #90 ·
This camper has a missmatch of drivetrain and linkage parts. :rolleyes:
Gearbox looks like a pre 82 one with the mount for the bearing pin and has an early relay lever fitted. The front gearbox mount has a strip of steel welded on to hold the linkage mount instead of it mounting to the gearbox.
Automotive tire Bumper Automotive exterior Gas Automotive wheel system
The linkage is of the later type (mostly) with the selector cup which isn't supposidly compatible with the early relay lever on the gearbox.
Gas Metal Pipe Wood Auto part
The rear linkage has this weld half way along which i assume isn't factory. Looks like two different bits welded together (maybe to make it fit).
Wood Natural material Road surface Asphalt Gas
Gave it all a coat of gloss black.
Tire Wheel Automotive tire Motor vehicle Hood
Wood Tool Lumber Composite material Hardwood
Discussion Starter · #91 ·
Looks like this van was built up from a bare shell using whatever one of the POs had lying around.
The gearbox is definately an early 6 rib (possibly aircooled petrol?) one like this with the earlier style relay lever mounted on the nosecone but with a diesel bellhousing fitted.
Automotive tire Machine Auto part Automotive wheel system Metal
The linkage is the correct (for the year of the van) later style but with the rear section of the linkage shortened to match the position of the relay lever on the box which is about 6" further back on the correct year box like this.:rolleyes:
Motor vehicle Wood Gas Automotive exterior Automotive wheel system
Discussion Starter · #92 ·
I've still not managed to get the linkage to work fine with all gears. 1,2,4 and reverse are great but in 3rd the lower ball on the relay lever on the gearbox pops out of the selector cup on the linkage locking it in gear.
Its using a diesel linkage with a dogleg in it like this:
Plant Road surface Asphalt Rectangle Grass
which is correct for a diesel van but as the selector shaft on the aircooled gearbox exits about 6" further forwards and maybe 3 or 4" lower the angle of the linkage is too steep.
It sits like this (yellow line) vs level as it should.
Automotive tire Motor vehicle Tire Vehicle Automotive design
I think if i can reduce the angle of the bends in the gear linkage (its only like 1" steel conduit) to straighten it a little it should sit more level and maybe not pop out.
Discussion Starter · #93 ·
Not at all like the factory intended but now all 4 forward and reverse are available once again.(y)
I finally managed to get it all working properly this afternoon. Flipped the diesel rear linkage part upside down, turned the mounting bracket over and split the U/J and flipped one part of that over as it hit the handbrake rod. All gears are easy to find and it shift surprisingly well. Gearing is horrible though as hills my caravelle storms up in 4th, this 1.9 n/a diesel struggles with in 3rd. :rolleyes:
Automotive tire Tread Tire Hood Automotive lighting
Wheel Tire Automotive tire Vehicle Tread
I don't think i've seen one of these seatbelts on an 80s car before.
Outerwear Light Sleeve Purple Tartan
Hand Sleeve Finger Bumper Nail
81 - 93 of 93 Posts
