1956 split with straight axle conversion & 12 volt 1600 t/p engine with alternator.
I tried starting (& failed. see other post about the startrer issue) my bus for the 1st time since doing the straight axle conversion & engine upgrade & I have a problem with the warning lights on the dash.
I have a green (oil) light & a red (generator) light but the oil light stays on & the generator light doesnt even light up.
I have fitted new bulbs in both & have even swapped the generator light bulb for another I know works.
Have I re-connected something wrong when fitting the alternator & engine?
The bus had the stock 6v engine with dynamo & piggyback regulator prior to the conversion & I noted the position of the wires before removal so Id know where they went when I came to put the new engine in.
I had the following:
blue/green to the oil pressure switch from the main loom
black/Red to the regulator on the dynamo
blue to regulator on the dynamo but the 2nd terminal.
Black to lh terminal on the coi
Green to the rh terminal on the coil.
I have replaced them like for like with the exception of:
black/red going to B+ on the alternator
Blue going to D+ on the alternator.
Have I done something wrong or was it wired wrong by a previous owner?
Can anyone help?
I dont want to ruin my new engine cos I dont know if the generator is working or if I dont have oil pressure.
thanks
mark
sorry to hijack a bit but where does the regulator go in that diagram im gusing its inbetween b pluss and the batery but what wires go where from it when its coming from a alternator
Thanks Phil
Tech Guru/Mr VZi '06
Can anyone help?
thanks
mark
Pull the wire off the oil light switch and see if the green light goes out.
Pull the blue wire off D+ and touch it to earth to see if the red light comes on.
