Large collection of performance engine parts for sale. Almost enough to build a 2007cc engine.
Prices and condition of each item is listed below. Prices do not include postage. I am based in East Grinstead, West Sussex.
Photos are available here: Engine Parts for Sale
Please message me directly if you're interested in anything. First come first served basis. These are advertised elsewhere.
ItemConditionPrice
Type 1/3 AS41 'super case'. Clearanced for 82x90.5, galleys drilled & tapped with unions (by Stateside Tuning)Unused, was part assembled. Missing 1 case saver
£800​
Street Eliminator Cylinder Heads. 40x35.5 valves. 98mm bore. 50cc capacity. Probably BugpackUnused. No packaging
Sold​
Scat Thin head light weight cam lifterUnused in original packaging
Sold​
Bugpack 1.4 ratio rocker armsUnused in original packaging
Sold​
Scat (?) crankshaft, counter-weight, 78mm stroke, forgedUnused in original packaging
£450​
Mahle 90.5mm x 82mm barrels & pistons, forged (98-1991-B)Unused in original packaging
Sold​
Engle Turbocam TC10 284/276DX. 430/. 420L (p/n ;21-4210)Unused in original packaging
Sold​
Engle Camshaft W100 420L/276D (p/n 21-4100-0)Good used. Has original packaging
£50​
Engle Camshaft FK89Unused in original packaging
£120​
Engle Camshaft FK8Unused in original packaging
Sold​
CB Performance Super Race Rods H Beam 5400, VW JournalUnused in original packaging
£325​
CB Performance Super Race Rods H Beam 5500, VW JournalUnused, small traces of rust from storage (none on bearing and gudgeon pin contact surfaces)
£250​
Weber (?) fuel injection IDF pattern throttle bodies 99030.520Unused in original packaging
Sold​
Short IDF inlet manifoldsUnused, no packaging
£80​
Empi Aluminium Push Rod Tubes (00-4109-0)Unused in original packaging
Sold​
Bugpack Hi Performance push rods (one end uncut) 4084Unused in packaing but missing two ends
Sold​
EMPI 8mm C/M Case Studs Stock Length (00-4020-0)Unused in original packaging
Sold​
Lightened flywheelUnused, light rust from storage. Needs light cleaning up
Sold​
Lightened flywheelUnused, some rust from storage. Needs cleaning up
Sold​
Bugpack hardened Lash Caps (4029)Unused in original packaging
Sold​
Bugpack Teflon wrist pin buttons 90.5 (4594-12)Unused in original packaging
Sold​
Empi Chromoly Gland Nut (00-4026-0)Unused in original packaging
Sold​
Aluminium rocker coversGood used
Sold​
Sump extensionUnused, no packaging
£100​
Straight cut cam gearUnused, small traces of rust from storage
Sold​
Gene Berg full flow oil pump coverUsed, some wear on the surface
Sold​
Scat 180mm Lightweight 4-Puck Clutch Plate (60045)Unused, no packaging
£30​
8mm case studs (unknown brand)Unused, no packaging, some rust from storage
£10​
Empi rear support kit (00-9543-0)New in packaging but missing top strap
Sold​
Hi-flow 30mm x 8mm Aluminium Oil PumpUnused in original packaging
Sold​
Empi Urethane Gearbox Mount Kit (00-9540-0)
£30​
