1 - 2 of 2 Posts
Hello, I've got Pertronix electronic ignition, not fitted yet, coil and leads on the way from Carshopinc.com (£54 all in!). When I get them, I'm planning on fitting them myself. Is there any special procedures I should adopt or is it a simple case of taking the old bits out and replacing with new?
I want to be sure so I don't melt the engine in the process! (it's a 1500)
Thanks :hangloose
Just done it myself, peice of cake.
The plastic collar for the dizzy shaft is a snug fit and needs a firm push.
Your leads may not have the plug ends made off, if so, get hold of a proper set of lead crimps, don't try and make do with small electrical ones.
Another thing, don't try & force the leads into the old holders, you'll damage the insulation.
PM me if you need any more info, but you should have it all there in the instructions
1 - 2 of 2 Posts
