1 - 13 of 13 Posts
Thanks for the replies guys!
I've had a poke around and it seems like it doesn't open anywhere else.
However I also investigated the small riser tubes and I think they may be blocked. Are they supposed to meet up? i.e. if I push a wire up one end should it come out the other end?
Superhero
If it leaks, than you'll get exhaust gas into car while heater is on.
that has to be the most uninformed reply i've seen :rolleyes:
The pipes are there to give a little heat to prevent carb icing. They should join and to be effective they need to be unblocked.
You could treat it like your oil light and put tape over it ;)
Good point about the leak.
Oil light: Bah! - I was young and foolish then! :D I learnt my lesson well. ;)
Hope you are well, matey!
1 - 13 of 13 Posts
