1 - 2 of 2 Posts
What exhaust would you recommend for a standard 1600 tp engine.It currently has a monza 4 tip which is a bit on the loud side.I would prefer something pretty quiet but more efficient than a standard one as I plan to add a 32/26 weber prog carb,blue coil and 009.I may run a standard one with taper tips until I have all the other bits ready to bolt on.Does anyone recommend electronic ignition over standard and why?
Cheers Jase
hi
Your monza 4 that you have on at the moment is an all in one system. so its go the header all ready built in.
You can get single and dual quiet pack exhausts but you need a seperate header for these. These are quieter than the monza and are good on economy.
have a look on www.streetstyleandpower.com
1 - 2 of 2 Posts
