I'm trying to fit a Grohe shower and the water inlets are a plumbing fitting I don't recognise.
They're designed with an offset to facilitate misaligned pipes which is great and all that, but the inlet as pictured appears to be compression style, however the hole is too small for 15mm copper pipe to neatly slide in as per a normal compression fitting. The thread is regular 1/2 inch bsp as per typical compression fittings, washing machine hoses etc.
I've never come across this fitting before and I'm not sure how I'm supposed to interface this with 15mm copper pipe.
Any clues?
Any clues?
