come on, someone must have used these
so does it matter which go top tube and which go bottom, was gonna do long top and 2 short bottom.Ok...your a tool...
The rims go on the outside( where og grease seal was)
The small ones with no rims are the inner ones (approx 6" inside the beam but check against a trail arm for exact position)
The long ones just replace inner and outer in one go.
Does that any make sense![]()
Hmmm.... must be ball joint type 1 beam .... long bushes in the top then.i ll think you ll find the tubes are different sizes
