1 - 2 of 2 Posts
recently welded my self some new wheel arches and primed them well with por 15
well por 15 reacts well cellulose primer as i found out yesterday
my question being
i was going to paint my rust spots with the por paint rust treatment jobby
can you use this with celly paint
thanks
Painting POR15:-
1. Straight over rusty metal.
2. On shiny new metal once treated with POR Metal ready.
3. Over existing POR15 paint provided it was fairly recently painted.
4. Over other keyed paints or primers.
Covering POR15:-
1. Completely key the POR15 surface with 400/600 grit paper removing all the gloss.
2. Use the special POR Primer designed to directly paint over.
3. For the underbody just use the POR chassis paint.
Beware using the POR primer. If you accidently sand through the POR primer right through to the POR15 underneath it will always react at those edges when you try a regular primer or top coat.
Hope this helps.
1 - 2 of 2 Posts
