1 - 9 of 9 Posts
I¥m wondering if its possible to fit Porsche Fuchs wheels onto a link pin car (from `58) using re-drilled drums. I¥m aware that there are issues with the early skinny rear drums/oil seals etc, but AFAIK its possible to convert the rear end to later (`66) rear drums and seals. The front end is what I would like to know about. Are there re-drillable front drums that will fit a linkpin front end and accept the Fuchs wheels? Would make life a lot easier than fitting a disc brake kit.
thanks! :)
Haven't seen any Porsche pattern front drums.. but Machine7 might be able to help on the custom front?
I guess that adapters or dropped spindles (to go to discs) won;t wash with the TuV?
:hangloose
I could use the CSP kit no trouble, but its a faff having to convert to dual circuit brakes (I think you have to) and I figure I spent about enough on this car for now!
Will give Machine 7 a shout.
cheers
Hmmm.... could be. Not sure if they¥ll go on a link pin stub axle is all.
Thanks though.
Thinking out aloud for a bit (I'm definately no expert on this sort of subject.... :eek::lol: ), would the early bearings fit in the later drum?
Do later front drum backing plates share the same bolt mounting pattern as a king and link pin spindle?
Martin.
BTTT
Anyone put late drums on early spindles??
They would, but still have the wide five pattern.
The best solution is actually 356C Discs, but I¥m guessing they could be pricey!
1 - 9 of 9 Posts
