Please can you have a look at the pic below and tell me what each of the jets are and what the carbs are jetted/set up for. Twin 36 Dells.
There may even be a prize for the first correct answer ;)
But probably not.
Cheers muchly :)
122 Mains
33 Pumps
52 Idles
180 air correctors I think
30 venturis
Pretty much jetted for a stock 1600 cc engine. Could do with uping the pumps to 50s for better response and the 30 venturis/chokes are a bit big maybe - will lose some low down power but will have a better top end.
there straight out of an alfa up the idles to 55 and they will work on anything from a stock 1600 to a 1776.
But as above bottom end might suffer slightly on a stock 1600 but i'am running exactly this set up and its fine, still loads more torque than stock.
cool, cheers just wanted to check. They're going on a mild 1776 with standard heads so I'll be OK then :) Just gotta make sure I put em back together properly-bits everywhere!
