How much of a ballache are they to replace? Are they expensive to have done?
I've just taken out the rear doorcard and peered down, and I can see light through the bottom (the edge that meets the running board)!! Everything else is ok (heater channel etc).
Thanks for any advice :D
You can get the lower repair section which isn't too hard to weld in assuming the wing and running board come off ok. Of course, the amount of work goes up greatly if it then needs to be prepped and painted.
Cheers Tomarse :D
Am I right in assuming that the bottom adge in question is part of the rear quarter and not the heater channel?
Yeah sounds like it's the quarter. The repair section goes all the way down to the bottom of the heater channel so it sorts out the whole lot if needed. :hangloose
Part no 4:
Bloody hell that was quick!! Cheers again dude, much appreciated.
Is that area an MOT fail for corrosion?
