1 - 9 of 9 Posts
OK - never welded before - want to learn. Any advice on:
a) A beginners welder - got a machine mart near me - any good uns in there?
b) Where to start - just try and learn myself or go on a course?
Thanks folks
Rich ;)
i have a clarke 135turbo. despite what some will say it is more than adequate for what most need it for. if i was using it daily for my living i would spend a lot more cash on one. it takes a bit of time/ practise to get it set right ,be carefull on how much tension you load the wire with to eliminate snagging.. and buy a large gas bottle and 5kg wire wheel to allow lots of practice. i get my bottles of Jawell paints. oh and a decent regulator for the bottle. no doubt some will disagree. but it works for me.
I agree with the above. I've got a SIP 150 Turbo, some say they're crap but it works for me and I can produce machine grade welds. At the end of it all, it's in the prep. If the prep is good then the weld should be too.
Good luck
Regards, si
I've had a SIP 130 turbo and now have the Clarke 151. I'd recomend the Clarke any day.
Ditto with the big pub size gas bottle... Makes a big diference, and a lot cheaper in the long run too.
One that works is good.......
Ive got a Sealey 160 Turbomig, more power is generally easier to control. It's all about practice, practice and more practice.
sip 150 topmig, had it 6 years and its my first welder... ooh the fun we've had!
i have a clarke 105, i have had it for 10yrs. It is now broke. i borrowed the professional one from my garage and couldn't believe how easier it was to use. So i say get the best you can afford.
1 - 9 of 9 Posts
