1 - 8 of 8 Posts
I've just had a right old 'oh shit'
I'm running chevy pattern on my '60 project, gear box is in, all built with T3 backing plates and gubbins sealed up etc, i was gonna get the 4bolt T3 drums i have redrilled but there's a hole clash...
In the shared hole, do you think a threaded insert would cut the mustard? I could therefore get the rest drilled.
As you cant get blank t3 drums (from m7 anyway), would i be better off redoing it with beetle stuff where you can get chevy drilled drums? In the words of Paula Abdul one step forward and two steps back!
either use adapters
or
get a taper plug made up with the wheel bolt sized thread on it and screw it and and flush it off. redrill the stud pattern and use studs instead of bolts
probably the most expensive but the best/cleanest way imho...
'cos type 3 rear drums are "hub" based...
buy some chevy pattern rear drums from M7... take them, and a type 3 rear hub, to your local machine shop... and have them machine the new drums down to match the hub... should be in the £25 region i would have thought.. you now have chevy pattern hubs...you can get the machine shop to put in the 2 locating screw threads or you can do it yourself...
thats how i get round the problem of having to find expensive type 3 hubs for the 914 rear disc conversion.. machine down a set of 4 lug drums.. works real good...
good luck with it...
use wide 5 t3 rear drums?
without looking at the book i cant remember if they are the same size as later 4 stud units dimensionally or if they are the same as beetle ones.
but then take to your machine shop and jobs a gooden :)
thanks chaps, very helpful.
Although its the easiest way, I'm a little concerned about danny's method as the drums have the raised bosses on the backside (not sure if this is just with repro drums), might the new holes be a bit thin with not much metal for the bolt? or require something behind them to beef them up? The bug has a pokey 1955, close ration box etc and will be used in anger!
buggsy, i thought of that but with the due to the crazy shape the hub, there is nowhere you can the 120 PCD to have a flat surface.
qwan, good idea :)
1 - 8 of 8 Posts
