You need the lever-action tool like:
http://www.germansupply.com/xcart/customer/product.php?productid=16522
If the ball joint shaft still won't come out, give the side of
the spindle casting a good whack with the BFH .
You'll have to jack up the torsion arm to get the shaft out
of the spindle. Do this in some safe manner that won't
injure the frt axle (or you).
Note where the "notch" in the top eccentric bush is pointing
so you can put it back approx the same.
