Hi, can any one tell me how do i attach a reverse light switch i:e were abouts on gearbox does it go etc, i have a 1972 domabile which has the reverse light in the tail cluster but it has no bulb/holder, i have been told that this was a change over year for the t2 any info would be great also does any one have a colour code wiring diagram if so where do i get one from
thanks.
Go here:
http://www.longenterprises.com/
(Great resource for all kinds of gbox info)
Click on "VW Transmission Diagrams"
Click on "Diagram #13" 002 Housings
On the nosecone section, part #24 is a plug screwed
in to a tapped hole.
Remove that plug (oil may flow out).
Replace with the reverse switch (part#26 on the diagram).
The switch is the same one as used on Type 1:
111-941-521
Run 2 wires from the switch to the engine bay.
All the connections are made in there.
An in-line fuse holder is tapped off the + side of the Coil.
It looks like:
