No - it means drill a hole in the throttle butterfly valve (the flat brass plate inside the carb that moves when you wiggle the bit the accelerator pedal is attached to).
Stock VW carbs have the same thing if you look throught them.
As for whether you should or not - I don't know. Maybe wait for a response from someone who has used these carbs - they aren't uncommon.
Neil
