1 - 20 of 68 Posts
Hi
Ive updated my for sale threads into this one........
All parts can be posted at buyers cost. Happy to accept paypal if you cover the fees or send as a gift. Thanks.
BEETLE
Lots of door handles, original and repro- please let me know what you need
Billet steering damper mount £35 Posted
N.O.S. Offside oval rear light housing for 61-67 & 1200 VW stamped £50
N.O.S. 67 Bonnet handle £95
Complete 67 Beetle lock set, both door handles, ignition switch, decklid lock plus bonnet handle including inner and also door latch mechanisms with correct lock pull and inner chrome handles- POA, may split
N.O.S. Cabriolet Bonnet lock/ pull handle with housing 61-66- can be used on other years but key codes correct for 61-66 £245
New boxed ATE twin circuit master cylinder (LHD) £155
New KYB GR2 ball joint front shocks £80
Original VW overriders for blade bumpers VGC but not perfect set of 4 SOLD
2 sets of Beetle side trim- first set is an old repro set purchased back in 1994. This is for pre 63 Beetles with the shorter bonnet trim and badge. Much better fitment than the latest available, near perfect SOLD
Second set is for 63-66 Beetles as has the longer wide bonnet trim. This I believe is original VW as has correct curvatures in all pieces and some side trim pieces have special shaping not on repro. There are some scratches etc but find another original set £135
CSP LHD shifter, new in packet. T handle with button and angled shaft so pre 67- £200
N.O.S. Hella Oval Snowflake light (1) £125
1302/3 front brake drums. New boxed £60
Proper old stock Boxed Bosch sloping headlight lenses 61-67 £140 Pair
King/ link pin Beetle drop spindles for discs- New £95
Original VW stamped rear blade bumper. Stamp clearly visible but will need some work and a re chrome or super solid rat look bumper- super rare and find another hence £225.......don't forget how much Taiwan thin metal ones cost!
Rear blade bumper- I can't see a VW stamp but pretty much same gauge metal as original above. Far superior to modern versions. Great condition SOLD
68 only Air filter- this has the twin inlet like 67 but single pre heat inlet £85
Original factory door cards, rear 1/4 cards, and under seat kick panels from a 72 Bug in very dark blue £110
Also have matched pairs of headlights for 53-55 and 56-59 Ovals, Beetles £varies
Super rare Dealership TYPE 1 parts book- bible for part numbers, colour codes etc- Have been informed these were only sent to the large dealerships that supplied smaller and only 6 made......please inform if you know more than myself
Discussion Starter · #2 · (Edited)
TYPE 2 BAYWINDOW
Pair of Original VW cab door outer handles
Early Bay VW Bilstein jack- complete with handle £75
Pair of Avis Adjusters 68-79 Look same as ones Limebug sells but these have been in spare room for over 5 years so teeth cut well and parts interlock nicely £75 inc UK post
71-72 NEW Crossover front discs- best German quality made by SEBRO £140
Original LHD latebay ZF steering box- very little play (if any) and includes mounting plate, bolts, washer and nut for drop arm £350 OBO
Pair of Latebay disc spindles- perfect for converting crossover bays to the bigger calipers, pads. Calipers also much cheaper and more readily available £100
TYPE 2 SPLITSCREEN
Rear bumper left overrider with towel rail corner, includes fittings and spacer intact on overrider- £75
Various rear driveshafts, axle tubes, reduction boxes, backing plates, spring plates- PM what you need
Pair of original (I believe as VW stamp) rear drums for 64-67, very little use if any £150
New 55-63 repro drum, unused £100
Various interior handles- all Gen VW in Ivory, Grey and rare black
Deluxe trim black insert roll- unused
Jailbar kit rear window by aircooled accessories, lost screws but otherwise complete and unfiited £30
Split nose cone 211 301 211C complete with kinked hockey stick £95
Pair of matched Hella 1955 Split headlights- extremely rare as all parts inc rim, buckets, reflectors have part number and Hella stamp visible £POA
T25
1.6D New AMC cylinder head (will fit Golf 1.6D). Asking £475 saving nearly £200
Think this can also be used for 1.6TD but please check
Discussion Starter · #3 · (Edited)
PERFORMANCE, ENGINE
Valve spring compressing tool, see post 8- £85
Pair of 9/10 mm aluminium wide 5 wheel spacers £40
16 Porsche aluminium wheel nuts- polished old stock SOLD
Spax coil overs used £100 pair
Fanhousing 36hp style for single port with heater outlets £50
Lightened original VW Flywheel- 130 teeth so 12v but 180mm clutch, clutch friction face good SOLD
N.O.S. VW OEM 25/30 hp Fuel Pump diaphram £65
3 x 30 hp Original VW Fuel pumps- varies on year you require....1 SOLD
1 x early pump pedestal, VW stamped SOLD
Scat deep sump- as new with pick up tube £65
Original Weber stamped 32/36 manifold section, much better than modern copies- £75
Engle FK89 cam- never fitted and clearanced £100
N.O.S. VW boxed 3 rivet camshaft (nothing better for stock build) £200
N.O.S. Boxed VW 25/ 30HP main bearings From £110 set
Bosch 009 dizzys (not repro) £50
Matched pair of Italian Weber 36 IDFs £425
Motometer oil pressure gauge with correct fitting for gauge and to sender £75
Lots of type 4 engine parts, all small items and also including
914 engine case- can be used for T2 builds with a few mods. This is the sought after case as fuel pump blocked in factory and no pump pushrod tube to deal with. Checked by machine shop and spot faced on barrel mating surface £450
New boxed type 4 Mahle 2l (94mm) Barrel & Pistons with correct dish £400
T4 96mm Old stock NPR 96mm Barrels & Pistons- far better quality than modern AA etc SOLD
T4 Scat H beam rods 5.325 for stroker cranks 22mm pin £375
As new AMC 2L head £300 SOLD
1800 S heads (the one everyone wants)- big valves 41mm.....all guides and seats good. A couple of cracks in combustion chamber (I wont say easy fix but easy for machine shop) hence only asking £450 the pair
Let me know your email for pics......these items are not on fbook or ebay
What vehicle are the Spax coil overs for? Front or rear?
Phil
Hi
I believe they were used in a Split originally, but they are quite slim so could be used on a Bug.
They are eyelet to eyelet so Pre66 front or any rear of a Bug.
If interested PM your mail and I'll send pics and measurements.
Discussion Starter · #8 · (Edited)
Bench mounted Valve spring compressing tool- similar design to original VW tool 311.
I believe this is home made but extremely robust and far stronger than repro versions available.
Extremely quick to remove collets and retainers......only selling as have purchased original VW tool
£85 posted- PayPal gift or add fees
Hey Andy,
What do you have and prices please
Hi Andy..any of those tiny grub screws that hold the door lock barrel into the casting? cheers - Rob
Discussion Starter · #11 ·
Hi Rob
Not that I know of.....I'll have a look through the handles and see if there is a broken one we could raid screw from......
I take it the screw isn't year specific?
Andy
Thanks mate..I'm not sure..screw has an unthreaded bit on the end..cheers,Rob
Whilst sorting I have come across a few dizzys....
All original VW/ Bosch......
Will get part numbers and prices but includes SVDA and DVDA for type 1 and 4 motors.....
Discussion Starter · #14 ·
Bit of a strange one-
Original VW flywheel lightened- 130 teeth so 12v but for 180mm clutch. Clutch friction face good £75
Discussion Starter · #17 · (Edited)
As new AMC Type 4 square port 2L head- 39.3x33 valves for very late bay 78/ 79 and early T25 aircooled engines or if your engine has had square exhaust port heads retro fitted
Very Very low miles, only a couple of hundred before stripped for bigger engine £300 (over £400 veewee) SOLD
1 - 20 of 68 Posts
