1 - 11 of 11 Posts
I need one spacer that slips over the brake master cylinder location bolts
There are two that fit inside the double skinned bulhead area (Napolean's hat) between brake pedal and mater cylinder
Vehocle is a 67 karmann kab bug
nixk - if you do have one, can you let me know tomorrow otherwise I'm ging to have to have one made up at an engineering shop - I have a spre'ish weekend and the ok to spend it on the car - this is the one bit that's stopping me from doing the whole brake system :rolleyes:
Dude you can get away with bolting it all up with just one spacer, then removing the bolt and fitting the spacer when you find one, if it saves you getting one made up specially...
Discussion Starter · #10 ·
andy - TBH - I had thought of that so I'll see what time I got left tomorrow . I need to pick up the brake pipes and some other stuff and not sure if I'll get time to get to a machine shop and I NEED to get this done this weekend
Nick - appreciate you checking !!!
1 - 11 of 11 Posts
