1 - 2 of 2 Posts
i have used one of those EMPI ones, takes a bit of work and its a head off job(obviously) if you use a decent T-Bar/socket/extention it eventually works, the one i did I have just blown out because i was trying to use a rachet when i started mine so the threads wernt brilliant, having said that it was fine for 4000 miles!
if you use the empi kit, you can buy the inserts from Just Kampers for about 3 quid, you`ll need to as well because it seems when you change the plugs the insert stays with the plug(mayby im just doing something wrong)
1 - 2 of 2 Posts
