I'm thinking of changing the hose on my breather box to stainless steel hose (rather than the rubber hose which is on there at the moment) and was wondering if anyone has any recommendations as to the cheapest place to buy this from ?
Mr.010 said:
I assume you are doing it for either the old hose needs to be replaced or for looks.
Yeah, well one bit of hose needs replacing as it's been rubbing on the top of the carb and worn through but mainly for looks.
dpetteng said:
Where can you get the metal tubing and fittings in the picture and what side braided hose do you use??
Are you asking about the metal fuel line?
The line is 316 stainless with a OD of .250" and a ID of .194". The fitting is a .250" compression Tee. I got them all from http://www.mcmaster.com/
The hose is 7mm German FI hose.
