Starter motor question.. Big thx for all help..
Right following on from earlier thread, i have the engine out of my bus and the battery earth lead to my chassis when i turn the ingnition the atarter engages but the gear doesnt spin, is this right? Also just before i removed engine it was spinning motor but very slowly..
Im confused :crazy:
All help appreciated
Russ.. :hangloose
If you've removed the engine, the starter motor has nothing to engage with, it turns the engine via the teeth on the edge of the flywheel, it does not turn anything in the gearbox. The starter motor should spin with the engine removed, so you either have a bad starter motor, or a bad solenoid, or both. If the starter is "engaging" (i.e throwing out the pinion), the solenoid is working, but may not be making contact to run the motor. Try tapping the solenoid and/or starter with a hammer, (avoid the fragile bakalite end of the solenoid), to see if that helps it to make contact.
Thanks guys for your help..
Russ..
