starting probs
691 Views 5 Replies 5 Participants Last post by  jd374
just went to start my motor and all i get is a ticking noise when i turn on ignition and nowt
Take a look at Speedy Jim's website here under "Why won't my engine start", then come back with more info.
sounds like the starter motor , get someone to turn the key while you look underneath (make sure its not in gear ) if the starter motor clicks then the solenoids ok and it maybe just jammed , twat it with a hammer while someone turns the key, again make sure its not in gear and handbrakes on ,
This happened to me last year and the whack with a hammer did the trick :)
It'll also just tick if you don't have enough power in the battery to turn the starter motor.
it dosent click its a tic tic tic noise wen i turn on the ignition, you think it still could be the starter, it was just starting ok about 3 hours before
