Every now and then my starter motor seems to be sticking. I turn the key in the ignition and it just clunks and does nothing. usually going thru some of the gears seems to remedy the problem. Is this just chance? what maintenance can be done to fix the problem?
Cheers :hangloose
If all the wiring is in good condition and you still have the problem it is most likely the solenoid is sticking. Take it apart, give it all a good clean and a tiny amount of vaseline and it will be good as new.
