Which way is best to go to straight axle my 66?. A kit like the Bus boys or sourcing parts yourself?
I've fitted a 67KG box and now need to look at fitting the drive shafts. The shafts fitted to the KG box are too short (The tubes are 400mm long whereas splitty shaft tubes are 440mm long). I also have a set of early Type3 shafts which are shorter still, though the hubs will be going on.
So what shafts / tubes do I need?
What have other peeps on here done?
