My splits got a 68 beam up front - although its still has drums up front.
It was lowered a few years back by cutting and twisting the beam.
I've always thought that the passengers side wheel never looked quite right, but wasn't able to understand why.
I've now fitted a pair of dropped spindleswhich widen the track by about 1 cm on each side.
I can now see that the edge of the wheel rim on the passenger side sticks out further than the one on the drivers side! :eek:
Even with 175 smart car tyres on, they foul the arches, and its not that low! :rolleyes:
What would cause this? Could it be that the arms aren't pushed far enough in on the offending side? If so, that sounds pretty dangerous! :mad:
What would be the simplest way to check this? :(
I'm going to have to fit 145's for the time being, but was hoping not to have to fork out on getting the beam narrowed. :rolleyes:
Please explain.
Thanks.
bad body repair accident damage repair?
Possibly.
Before I fitted the new spindles, the passenger side wheel always seemed to have a bit of neagtive camber. Just a touch, but enogh that I noticed it (others wouldn't).
I think it may be to do with the torsion leaves.
you'll probably find that most beetles are like that! The front always appears to be further out on the left - just not as noticeable at standard height with stock wheels, but as soon as things start getting closer it becomes apparent.*
this isn't to say that you should check everything - since the beam on yours has been altered, there's no guarentee it isn't fubar'd
the negataive camber could just be down to adjustment at the camber nuts - possibly 'over' adjusted to compensate for previous clearance issues. Worn torsion leave would affect the camber of your front wheels! A bent beam would however!
*EDIT: just re-read and noticed you talking about a Bus :eek: so my answer isn't all that relevant. I'll leave it up though
