1 - 1 of 1 Posts
1. splitty to 68 bay irs chassis - I fitted a 944 torsion housing hense sale -the pair £90
2. pair of alloy 944 arms -i think you can fit t25 hubs and stubs in them? -anyway thems £40 -the pair
3. complete rear end from a 924 's' alloy arms, narrow track = ie 71mm disc hubs with the housing £300
4. 67 splitty beam, nice and bars £50
5. beam leaves -a pair -missing a few £20
6 t25 servo was new, now isn't -£30
7. 1303 irs -late one single slide plater £50
8. starter £15
9 2 litre starter -busted bendix thread £30
10. 901 fan ring machined to 260mm £60
11. 914 case cut for above £100
12 type 4 to porker shroud -stoick oil cooler local £55
13. 993 radial mount front brembo's £125
14 996 rear mono block brembo £100
15 986 rear monoblock brembo £100
16 964 early front caliper -missing a 36mm piston £35
15 new 964 front disc £50
14 rhd splitty dash quite rust free - but cut below windows £90
13 t25 hydraulic slave mount £15
12 944 servo master cylinder and pot -iron filings £45
11 front 944 calipers -iron £65
10 front 944 early hubs £80
9 one odd front early 944 hub £40
8 944 spindles -ideal to weld on making dropped ones £10 a pair
7 bay hubs £10 a pair -ideal for using the tsuds
6 another 1303 gearbox irs £65
5 splitty torsion housing bars and springplates £100
4 splitty brakes -complete late set quite good £65
3 type 4 1700 w code for parts £100
2 228mm clutch -quite re-usable £20
1 some tin bay 1600 -2 litre
0 rear 944 calipers -2 pairs avail £50 a pair
-1 bay trailing arms £10 each
-2 chrome 30 horse dog house shroud and head tin £25
-3 type 4 coolers £15
-4 type 4 fan -no busted vanes £5
-5 type 4 car drive shaft £10
-6 bay brake back plates £10 a pair
-7 pair of heat exchangers
-8
will have a swapsies on
single cab drop gates -splitty
-splitty rhd seats
front slash cut bumper
late pick up rear window
porsche 11 blade fan and late alternator unit -ie the one that fits a 901 ring with the internal biggestrefdjkfwe
17 inch tyres 205 45 17
-and 255 65 17
928 rear discs -new
t25 heads
short astainlesss t25 j tubes
-stock 2 litre van stainless style can
splittyt 67 tank -12 volt only
21- flywheel with the input shaft bearing already in it
t25 drive safts, or something else about 54cm, with 100mm cv's
1 webor 40 with 32mm chokes - the giblets for 2 litres
air filtration devises for above
type 4 pork cooling linkage for high rise cb performance inlets
looom and switches -type 1/2 -what ever
can take to stonor park
:hug:
1 - 1 of 1 Posts
