1 - 2 of 2 Posts
This is weird.
68 bug with sway aways fitted. Top one was stripped and the bolt came out. So I adjusted the bottom one. It went down fine but one side was higher. anyway put different bolt back into top and adjusted (clockwise) both . instead of lowering car went up and still higher on left side. How should these be set? and I know this sounds stupid as I have virtualy rebuilt the car an I am stumped by what is probably a simple solution. Thanks
Regardless of the position of the adjusters, if it's higher on one side then something's wrong. Possibly a broken torsion leaf. I'm guessing you have the same shocks and tyres on boths sides? Are the ball joints pressed in correctly?
Secondly, it sounds like you are adjusting the adjusters the wrong way. Screwing the adjusting bolts in makes the car higher. ;)
1 - 2 of 2 Posts
