Does the T.25 gearbox fit a T1 engine with out a motor plate.
Would the clutch/cover plate need changing
Are the mounting plates the same as the T1 gearbox.
Does the T.25 come with 5 gears what ratio's are they.
If its an IRS box will it fit to a converted T1 chassis please
Any pictures please
Max
Answers in order:
Yes
Depends on year of T1 - use a late T1 clutch
? - If you mean bell housing shape/bolt spacing then yes
Depends on version - some were 4 speed, some 5 speed
No - won't go straight in to T1 chassis. Gear shift is not on nosecone as per T1
Moog
All my kit is 1972 late
You said the gear shift shaft is in a different place is there a mod to get this working or is it easier to put in 914 box?
Many thanks
Would love some pictures or links
Max
Looking at the links you submitted SpedyJim, the diagrms show the internal workings for IRS or Sing Axle to be the same. Is it therefore possible to fit the outside shafts to the Swing Axle Box or is the housing different too, so to go IRS would not need a new box?
