1 - 13 of 13 Posts
Rigt the engines gone in my 2.1 wasserboxer powered T25. How easy is the Gti conversion? what do i need? Diesel bellhousing, sump and crossmember? How easy is the plumbing/wiring? Anyone got the wiring diagrams?
Steve
Beardy, all year round.
Think very carefully before doing it.
I just sold a van that had this "conversion" done to it and it's not as easy as it seems.
You will need the engine (obviously) and loom from your chosen donor plus all other ancillary sensors etc, and a diesel bellhousing from a t25 box. Make sure you get the lot, and i mean the lot.
Also put in your budget for a decent clutch, there are specialist items out there but you are talking in the region of £450 (ouch :eek: ).
Also bear i mind that these engines run a fair bit hotter than your standard wasserboxer engine, i have a Golf Mk1 Gti and the temp gauge is always just above the middle around town, about halfway on the motorways so you can imagine what that's like in a van.
I'm not trying to put you off but just make you aware of the potential pitfalls, it's not as cheap or easy as you would first think.
Check out the alternate engines section on the club 80-90 forum for loads of advice.
Good luck ;)
ok, but will this work on a slant and what engine mounts are required?
The GTI motor will fit relatively easily. I'd use a later golf diesel clutch and flywheel, bigger diameter and built to take the torque.
OK, so lets start a parts list:
T25 Diesel Bellhousing
T25 Diesel Engine mount bar
Golf Diesel Flywheel/clutch
T25 Diesel Sump
Golf Gti engine (digifant or K jet??????)
Exhaust parts (to make an exhaust)
What else?
Steve
T25 input shaft,engine mounts,and brackets,header tank and hoses,dipstick and tube,starter.
Personally I'd go for an Audi derived motor, being longitudinally mounted in the Audi,the manifolds are better suited to the conversion.
Either a 1.8 K jet, 2.0 digi or a 16V would be possible.
bloody hell this is more in depth than i thought. Have you done one of these before raddubs?
I've done later 1900 TDI into T25, and i've been involved with VWs for 20 years, spending nearly 10 years breaking all models,of VW and Audi H2O, so I do kinda know my stuff. ;)
Discussion Starter · #10 ·
furry muff!
do you have any of the diesel bits i need then? sump, Input shaft, bellhousing, mount?
steve
Know nothing of golf GTI engins, but I had a MK2 passat with a 5 cylinder engine and it was quite simply the nicest engine I've ever encountered. Every time I bought parts for car at VW dealerships someone working there would always say "ooh - best engine VAG ever made that". They somehow managed to make it powerful, torquey as hell AND economical too. You can get a converter bellhousing from a company in South Africa where this engine swap is fairly common amongst T25 owners. Might be cheaper than golf gti engine and the 5 pot engines renowned for doing 250,000 plus miles without missing a beat.
If you are unsure of anything give Simon a call at the Brickwerks. What he doesn't know isn't worth knowing.
The one i had in my bus ran like a train, but the wiring that someone had done was abysmal, as was a lot of the other ancillary bits. That is why i was saying when you get the engine get everything. Loom, header tan, coil, brains, the whole 9 yards.
1 - 13 of 13 Posts
