Hi all, I have a 1972 type 3 squareback....it needs a gearbox and i've found one but all the info that I have is that it is a type 3 gearbox, i dont know what engine size or year its from
Will it fit my car, or is there any obvious way of telling if it will be ok in my car??
Jay :D
You need to check the transmission number code letters. You will find it on the right hand side, forward of the axle shafts and facing down slightly. The number is 'punched' and not 'raised' and should start with two code letters. With no other info on your car, I think the code you are looking for is "DC".
Thanks...the guy reckons that it will fit
I will check mine tomorrow and see if they are the same
