My auto gauge tacho is cutting power to my engine. When it's connected it wont start when I remove the wire from the negative connecter on the coil she fires straight up. If i then touch the wire to the - connecter on the coil she sparks and the engine cuts out imediatly. Yesterday she was working fine with the wiring unaltered from what it is now. Any ideas?
I was hoping not it's a long way from the coil to the tacho :rolleyes: :incheek: I guess i'm gonna have to jack the bus up and trace the wire
if the coli to tacho wire is earthing out your coil wont be getting any power, no power=no sparky....
best be is to get a long reel of wire and connect it up at both ends, then see if the problems cured, if it fine, id pul the old wire out with the new one attcached, depending on how you've routed it tho......
