is it a secret??
as far as i know its just where the oil gallery is machined (drilled from the front of the case during production, the ones on early cases ar plugged with a solid bung and later seem to be a threaded allen bolt type, i think it would be quite a good place for my oil temp sender as oil is always flowing past that point, also considered drilling and tapping the bung on the top of the case (the one behind the distributer on the left) anyone have any opinions on the best place to mount?? i recon the bet place would be the plug on the left half of the case in the middle of the bottom oil gallery as i think this would measure the temp of the oil as it flows to the crank...??james_stan said:Sorry to hijack this thread but anyone know the purpose of this access hole ? Often wondered..
BR
James
nice one pete, i'll check that out as im just going by something i read and not investigated it myself,Peter said:I am fairly sure that it access' an open area near the cam shaft gear and would only receive 'splash' oil, so not a good place to put the sensor.
