1 - 12 of 12 Posts
is there supposed to be some kind of sealing strip or somthing on the bonnet? i get a hell of a lot of air movement from behind the glove box and the stereo,....and i have 2 duvet's stuffed in the luggage area to supposedly help?
is there an answer?
i like the draught that comes through my glove box - it eases the fumes smell for the passenger :incheek:
Although, saying that, I would also like to know if there was some sort of seal available for it?!
Do you have a proper full bonnet seal installed, and the blanking plugs in the wheel well? If not, you'll find it difficult to stop the drafts.....
I'm sure there used to be a cardboard type cover that covered the whole rear of the dash area (fuse box, wipers speedo and glovebox) that would maybe help - then, you would have to find one first.
Other than that - just tell passengers to stop being such wusses. :incheek:
so, there is supposed to be a sealing rubber around the bonnet? does it fit to the bonnet or the car?
i have the cardboard tray thing, and i have a front valance cover....
The standard European seal fitted to the car.
The Mexican seal fits to the bonnet.
Mexican one is popular because it just clips on.
so it sits in the lip on the bonnet? does the european glue in?
European one is held in place by a steel strip spot welded onto the lip of the bonnet opening (top of front 1/4 panels), which is curled over to grip the seal. Most of them have rusted away by now.
Don't forget, if you want to fit a Mexican seal, you still have to have a section of original style bonnet seal across the back edge of the bonnet (mounted on the body in front of the windscreen.
The Mexican seal is a doddle to fit to the bonnet. VW Heritage supply it either in pre cut lengths, or by the metre off a roll (cheaper).
Also, the Mexican seal can be used on the engine lid to replace the engine lid seal, by fixing it to the lid itself.
I used a self adhesive seal for the scuttle (in front of the screen), and Mexi clip-on for the rest. Snug as a bug (pun intended) :D
1 - 12 of 12 Posts
