Whilst restoring our own cars we have come up with the idea of making kits to save money and time for everyone and to try and bring down the cost of restoring VW's
The Following kits are avalible from us in stainless unless stated.
Chassis Kit
From what I have seen, this is the best kit on the market by far, let alone the cheapest
22 Stainless chassis washers
26 Pointed bolts (4 for the rear cross member)
4 Large bolts for the bulk head
4 Small washers for rear cross member
2 large bolts for body to shock mount
2 thick washers for body to shock mount
2 bolts where your body bolts to the top of the beam under the petrol tank
£40.00
Door Kit 68 on
12 large allen head bolts to replace the cross head bolts in the hinge
12 small allen head bolts to replace the striker plate bolts and door lock bolts in the door panel.
I have looked at replacing all the internals on doors but I can not see the point as I have never had a problem with these ones. Although if you did want them I could do them.
£5.00
Door kit Oval
16 large allen head bolts to replace the door hinge bolts
6 small allen head bolts to replace the striker plate bolts, these are machined by me to get them to fit.
8 even smaller allen head bolts to replace the door lock bolts in the door panel.
£8.00
Under bonnet kits
These kits replace
petrol tank bolts
hinge bolts
bonnet handle
petrol tank flap bolts
These kits are for
1303 £3.50
Bug 68 on £3.50
Oval £3.00
Suspension Kits
Please note all these kits are in zinc plated high tensile steel and not stainless. These kits are can also be done in titanium, but be warned it is very expensive. I can let you know the prices for titanium if you want them.
Spring plate IRS
Spring plate swing axle
IRS shock bolt kit
All these kits are
£2.50 each
I will add kits to this list as and when I make them.
Postage on the kits varies. I can post upto 2kg with Royal Mail which is insured and gauranteed for £7.40. I can post the smaller items 1st class, I have done this with certain people and they have recieved their goods, but this way is at your own risk as we all know what the mail service can be like
If you are interested in any of the kits or want to know any info please mail me on
[email protected] putting chassis washers in the subject so I know it is safe to open it.
Thanks and happy restoring
Skids
