1 - 2 of 2 Posts
just had a tie rod delivered to work and want to check that it is going to be long enough as it seems a little too short.
on the invoice it says its a standard short tie rod arm with no ends, measuring in at 184mm. It's supposed to be for the steering box to spindle section driver side of a rhd 1200 1972 but look shorter than the one that came off. please can someone put my mind at rest that it will fit as i am going to fit it later this evening and hopefully put the bug through its mot tomorrow.
cheers
Nick :hangloose
Discussion Starter · #2 ·
panic over....just called my mate who took the old one to try get the ends out (which had fused in with rust) and they are roughly the same length....seriously relieved now! :hangloose :D
1 - 2 of 2 Posts
