It's not an issue thats going to end up in your engine dying anytime soon. You may find that your flywheel oil seal won't seal though and you get a leak between the engine and gearbox.
I've seen loads of engine with much more end float run on and on and on and on.
I wouldn't worry about it...
tom.
As said above. If its 4mm its bad, 1mm is more than you should have but there are plenty of engines around running happily like that.
Don't sweat,
Adrian
