Spray easy start down number 2 throat while it's running. If no 2 doesnt come to life, the carb is still blocked/miss adjusted.
Thanks mate I'll give it a go.Spray easy start down number 2 throat while it's running. If no 2 comes to life, the carb is still blocked/miss adjusted.
Thanks mate I'll try blowing out the mixture screws.Take out the idle jets and the mixture screw and blast air down the holes both ways, check and blow out the idle jet and see how it is, mine has done it few times and that's cured it every time
No I haven't tried that yet but jets are all clearhave you swapped jets over from side to side and see if the problem still persists
Get them pro cleaned. I had 1 that was a pig, always clogging and o matter how many times i cleaned it never cured it so i bit the bullet and sent them to https://weber-carbs.co.uk Paul did a full clean, service and posted back in 2 weeks and so far perfect. Far cheaper than buying a new set tooOk I've literally blown a hurricane through every jet and passage way and still can't get the carbs to run...I may have to just bite the bullet and buy a new set unless anyone has any other ideas????
