1 - 20 of 26 Posts
I have decided to sell the following parts as realsitically I,m never going to get around to racing again........
My tube framed Ghia will be coming up soon too once I get some new pics.
Engine bits:
CRANK AND RODS: SCAT VOLKSTROKER 2 82MM STROKER CRANK/PORSCHE JOURNAL NEVER USED.
BUGPACK RACE RODS PORSCHE JOURNAL 5.352" LENGTH. TWO SEASONS USE. £400 for both.
PISTONS/CYLINDERS: EX-MARTY STAGGS STROKER HEIGHT 90.5s WITH CHAMFERED DOMES, TOTAL SEAL 2ND RINGS, TEFLON BUTTONS.
CYLINDERS HAVE BEEN POWERSLEEVED TO FIT HEADS CUT FOR 94s. WILL TAKE 40LB BOOST. FEW RUNS USEAGE ONLY.£150
HEADS: EX-MARTY STAGGS TURBO PREPPED STREET ELIMINATORS.COPPER SEALS."They have custom sized valves that are around 45 x 38mm (stainless steel). They also have special dual springs that are VW diameter but have 340 pounds of pressure at full lift. This is about 40 to 50 pounds better than most and is my preferred setup. I have never had valve float with these. The retainers are Ti. They are fully ported and polished and have had the chambers re-worked for turbo use. The chambers are 60 cc's. They are used but in perfect working order." £500
HOLLEY 650 CARB WITH POWER VALVE CONVERSION BY MARTY STAGGS.NEW UNUSED WITH FILTER.£215
TURBOCHARGER TO4B. NEW UNUSED.£400
DELTAGATE WASTEGATE.NEW UNUSED.£100
OBERG SCREENED OIL FILTER.USED. £30
LIGHTENED FLYWHEEL. SURFACE RUST ONLY.£45
1.4:1 RATIO ROCKERS.£65
3/8 MOLY PUSHRODS.NEW UNUSED.£25
BERG OIL PUMP.NEW UNUSED.£40(sold)
BERG OIL PRESSURE RELIEF COVER.NEW UNUSED.£10(sold)
SCAT MOLY GLAND NUT. NEW UNUSED.£5
Postage will need to be sorted obviously.........
Cheers,
Ross.
rockers
do you get what you see in the picture shafts etc i will have them,
any idea on postage costs or collect at dubfreeze pls.
can post payment or bank transfer to you.
Ross,
Sorry mate I have pmd you already on callook lounge, and unfortunately I havent recieved your reply.
Really interested in the turbo, carb and wastegate, but could you please give me some more info on the carb (is it new, jetted for a particular size motor, has it the vacuum secondary etc) and turbo (make model, a/r, carbon seal for side draft etc)
Thanks mate ;)
Discussion Starter · #12 ·
Ok, let's keep this fair...
Pike was in first for p/rods and nut...........£30 plus £5 p&P? Mail me if that's cool Pike.
Mygod was first on rockers, so £65 plus £5 p&P? Mail me for details if that's cool.
Poe, you got proper mail mate.
1 - 20 of 26 Posts
