Type 4 aircooled camper engine {ca code}
Had been taken apart with the intention of rebuilding to put back in camper.
Bought all parts required for rebuild then decided to go with 1600 engine instead.
Around £500 of parts bought for the engine, seals, new valves where required, all new valve guides (replaced by blane presicion engineering) valves lapped in,exhaust, piston rings, oil seals inc crankshaft seal, big end bearings, service items etc. Needs lower tinwear to complete and other tinwear repaired/ replaced. Engine was running when removed from camper.
All components from megabug, the receipt is around somewhere.
All just lying in the garage doing nothing.
Also blane engineering replaced a spark plug insert when they had the heads.
£600 ono
collection.
Its a pile of parts. Engine was stripped, parts needing replaced identified and ordered. Then went with another engine. So its a pile of parts in need of reassembly. Hope this helps.
