81 - 100 of 104 Posts
Discussion Starter · #81 ·
Cool :)
Be careful with the rod bearings. I bought direct from Wolfsburg West and they were too loose on the crank journal. The machine shop managed to find one of the last set of a local quality brand. Big end of the rods also needed resizing as had ovaled.
So just a few things I found when rebuilding my 36er ;)
oh, and exhaust valve guides were flogged out too so entire heads got rebuild but I did get 3 angle valve seats for free ;)
The bug came with a 58 engine that had been refurbed ,new bearings etc,the 56 i found was seized so i'm basically using most of the 58 parts in the 56 case, with exception of new valves,rings etc
I was surprised with what the machine shop found on my engine. I have a set of micrometers and telescopic bore gauges and everything was still within std spec apart from the rods. Both big and little ends were out of spec.
Anyway, this is me being overly cautious but personally I'd have this 'reconditioned' engine measured by a machine shop just to ensure everythings good. People throw new bearings in and expect everything to be fine but even with quality bearings you can have the oil clearance tolerance end up too big or small.
At the least buy some plastigauge and assemble parts in sections, like crank n case then crank n rods. If the plastigauge shows clearance is within spec then you should be ok but if it shows too close to either end of the allowed tolerance then I'd get those parts looked at more closely.
The engine will last much longer and run more smoothly if it's nicely within spec ;)
Discussion Starter · #83 ·
Carpets turned up wednesday ,ordered them early March !!, being returned hopefully today. 5 pieces wrong,stitching on the tunnel piece shocking not impressed at all, colour was right tho. Spoke to them yesterday they wanted pics & details of what's wrong,hopefully they will sort them out quickly as these are holding me up now finishing , not happy !!!
What company? Not Newton Commercial?
Discussion Starter · #85 ·
Mmm yep, they were collected today & i should get a call on monday to discuss them !!!
Bummer, they were so spot on for my Ovals full carpet set. Even the wrong colour they sent to me was spot on and the colour due to the local company being dipshits and forwarding the incorrect colour to Newton.
Hopefully this is not becoming the norm for them as they've always had a good name for quality from my understanding.
Discussion Starter · #87 · (Edited)
Carpets sorted ,issues i had were quickly sorted by Newton Commercial,top customer service, carpets in,seats in,seat belts in & engine nearly ready for a test fire up before going in.
Brown Automotive design Rectangle Personal luxury car Auto part
Car Vehicle Motor vehicle Hood Automotive design
Brown Car Vehicle Car seat cover Motor vehicle
Car Vehicle Motor vehicle Steering part Automotive design
Motor vehicle Automotive tire Automotive design Vehicle Rolling
Automotive tire Motor vehicle Picture frame Gas Engineering
Discussion Starter · #90 ·
Have completed the engine & made a stand to test run it before sticking it in the bug . Had a go at running it on sunday,realised i had two plug leads mixed up ,school boy error, got fuel up to the carb ok & oil pressure too but no spark. Eventually worked out it was a points problem even tho new ones were fitted so waiting on a new set to arrive & fingers crossed it runs.
Automotive tire Motor vehicle Automotive design Automotive exterior Rim
Automotive tire Motor vehicle Asphalt Bumper Automotive exterior
Administrator
Discussion Starter · #92 · (Edited)
Got the engine running last weekend out of the car ran sweet as,then after a bit of trouble got it in the car. Today have got it wired up,fuel lines & filter fitted, heater pipes & cables connected,starter motor in & battery connected. Stuck fuel in the tank,cranked it over & oil light went off & got fuel up to the engine. Waiting on an accelerator cable return spring & correct size fanbelt to come then it's a trial drive out !! Finishing touches got door pulls fitted & the hand painted vase from my 6 year old grandaughter who's bug it eventually will be when she's old enough to drive. But getting there now :)
Vehicle Automotive lighting Hood Motor vehicle Car
Automotive lighting Automotive tire Hood Vehicle Motor vehicle
Vehicle Motor vehicle Car Steering part Steering wheel
Grille Automotive lighting Motor vehicle Hood Car
Discussion Starter · #93 ·
Had Wolfy the quality control officer inspect it & sign it off :D
Motor vehicle Hood Vehicle Automotive lighting Automotive tire
Vehicle Car Motor vehicle Steering wheel Automotive design
Land vehicle Vehicle Motor vehicle Automotive design Car
Discussion Starter · #97 ·
First drive out the weekend,only done two miles just to see how it went. Gears were a struggle to get so ordered all new bushes & plate,forgot to renew that,they were there just sloppy lever. Brakes good,steering all over so going to book it in for the tracking to be looked at. Other than that ran a treat,loved it.
Car Tire Wheel Land vehicle Vehicle
Tire Wheel Sky Vehicle Car
