....in the market for a round fuel gauge to match VDO fuel sender with part number 21 89 7 64 (metal tube type), so I can enjoy the luxury of having a fuel gauge!
Anyone know if pretty much any VDO fuel gauge, even a modern one with white dial face would be any good? Ta in advance. :)
http://www.egauges.com/eg_typeI.asp...ll&Bezel=All&Needle=All&Diameter=All&Manf=VDO
shows the dazzling array of styles VDO makes in fuel level gauges.
I do like VDO's "Ocean Liner" series! :D
But be careful because each gauge style is available to fit
a number of very different senders.
http://www.egauges.com/vdo_sgrp.asp?Subgroup=Fuel_Senders
If you can't find the VDO P/N stamped on yours, use a multimeter
to measure the resistance range. The first number in the
sender listings is the Ohms when EMPTY and the second
number is Ohms when FULL.
http://www.egauges.com/vdo_send.asp?Sender=VDO_Adjustable
Then order a gauge P/N intended for your sender range.
You can find a UK supplier with the same stock listings;
I merely posted this supplier as a reference.
Perfect, many thanks! :)
