1 - 18 of 18 Posts
Looking to build a respectable type4.
Got a case and heads but need some oher bits.
Ain't rich but have got some cash available
like what?
whats it going in?
what cooling are you using?
what heads do you have?
I've got both 1800 and 2000 cases as well as a set of 1800 big valve heads.
Stock cooling system
Looking for!!!!!!!!!!!!! crank!! cam and followers, pistons/barrels
what's the verdict on stock fuel injection system (can't afford or get my head around megasquirt)
i have std
both 1800 and 2lt
barrels and pistons, crank, rods and cam etc
cranks will need work (seized bearing)
and 6 1700 heads some will need work (oval port) they will require the seats boring to take 1800/2lt barrels
and loads of bits and bobs left over
I've got a crank & rods but may be interested in the P & B's
What make are they and how much?
71 mm counter weighted crank
4 connecting rods - balanced both ends
4 96 mm cylinders
4 96 mm hyperutectic pistons - ceramic coated tops - weight matched balanced
1 set 96 mm total seal rings
1 set 96 mm Grant cast iron rings
I bought it all from the states, i was told that the pistons kit was KB but i cant guarantee that.
Makes 2056cc. The crank has i little bit of surface rust where its been sat for a while, can get pics.
£280 Posted
4 96 mm cylinders
£280 Posted
I'm also interested in this kit, but Nova is first in line I guess!?
Can you do pics please?
Cheers,
Dan
Hello again peeps, here are some of the pictures, as you can see the slight rust on the crank, this is the worst part i have pictured.
Searching for rods and pistons at the moment
As far as i gathered when i bought it, the B+Ps, rings etc were new crank used, but good, balanced etc.
I have had quite a few PMs offering money and to buy it straight away, but sorry there is an order of people waiting for it all.
So let me know asap if wanted.
1. Nova
2. Dan
3. Mike
1 - 18 of 18 Posts
