1 - 2 of 2 Posts
first time posting in here and a pretty straight forward question to start with too. i`m preparing a chassis for some high performance mods which will eventually have a turbo motor stuck out back.
i`ve got a 55 chassis and a 63 chassis and i`m wondering which is best to use , the earlier chassis has no bump stops the later one has , is this a good enough reason to go with the later one ? or is there any advantage to using the earlier one ? is the early one stronger or more suitable in any way ? i was planning on fitting the eyeball engineering package , seam welding the frame horns and the frame head .
i`m thinking go with the later one simply cos it has bump stops , stop me if i`m wrong
1 - 2 of 2 Posts
