1 - 20 of 34 Posts
hi what is this as i do not have it on my bug and mine is the same year an model as this 1
eney 1 no ??
yer u may be right but its not the same type as what i have on my bug
Are you sure it's not just been removed off your bug. What year and model is yours? I think the type of Z-bar upper mounting changed around 68-69. The one in the picture, correct me if i'm wrong is a later z-bar.
Some people just remove them, especially if you've got a lowered rear end.
25 character limit is cra
Speedy Jim said:
It's part of the "Z-bar" stabiliser.
What he said.
Standard on 1500 and GT Beetles, an option on others in the 70s. A mate had one on his 1973 1300. :)
There were 2 designs of Z bar, they look different, but do the same job.
frizzer said:
I've got one of those on my '72 1300.
I always thought it was some kind of anti-roll type thing.
You are right, (sort of), there has been much dabate over what a Z bar actually does, but VW said it was meant to " give more neutral handling characteristics ".
No, it's the opposite of an anti-roll bar, because it's Z shaped :)
my bug is a 1300 73 the same as whats in the pic but i gess i dont need 1 as im geting a different set up but cheers for ya hellp :D
al_kaholik said:
in normal use it does absolutely FA...
Unless you lower the rear suspension to make the Z-bar operate all the time, then it starts to get "interesting". :D
What happens if it's been lowered?
Mine's been dropped one spline at the back and so far I've not noticed anything too bad - or am I not trying hard enough ?! :crazy:
The handling of a beetle can be good(ish!) The 1300 recon in a bug lowered with Zbar and ARB at the front was so much more fun that a stock height 1200 with no ARB on the front and no Zbar...
Made me scared to think of the 1200 going around corners at 3/4 the speed I did in the 1300
1 - 20 of 34 Posts
